I’ve designed this board up with a ground plane on the top copper layer, generated using Proteus Ares. For some reason the DRCbot keeps hilighting my ground plane as violating 8mil 8 spacing - even though the tracks it uses are at least 10mil and with a 15mil clearance.
I’ve emailed support@, but has anyone had a similar sort of problem before?
naxxtor:
I think the issue is at the lower left. Four holes in a square, upper right corner of this square, where ground plane almost disapppears. It looks thinner than 8 mil.
Well, it shouldn’t be. I’ve set the track width on the plane to be 10mil spacing - that said I’m not sure how it actually generates the ground plane in the gerbers.
The fact there are no G36 or G37 codes suggests that maybe the ground plane isn’t a poly - but then I don’t know how most software does ground planes so I couldn’t be sure.
felis:
Oooh, that sounds probable. I’ll tweak that and see what happens.
I hope it’s not the space between the 0805 components that’s doing it, because that’d be exceptionally annoying to fix >_<
I don’t know, the ground plane still goes between some of those solder pads and looks thinner than those 10mill traces. Like at the bottom it looks like two LED/resistor combos. There’s small ground plane tracing between. I’m not certain if the DRC takes just what has been marked as orange into consideration, or if it also includes the green trim.
