The new EW-7611ULB Edimax (v2) BT/WiFi dongle requires a new driver from the dongles previously included in the SparkFun Jetbot kits. There is a great thread on the [Nvidia forum for getting started with installing the new driver.
Steps:
- Download Driver from [[Edimax website](https://www.edimax.com/edimax/download/download/data/edimax/global/download/bluetooth/ew-7611ulb_v2)
- Extract **.zip** file
- WiFi Driver:
- There is a post about it here: [https://forums.developer.nvidia.com/t/e ... /165047/13](https://forums.developer.nvidia.com/t/edimax-ew-78111un-v2-wifi-setup/165047/13)*
- In a terminal, navigate into the **WiFi** folder of the extracted **.zip** file
- Run the following commands:
export ARCH=arm64
make
sudo make install
- BT Driver:
- The instructions are in the Readme.txt file of that folder*
- In a terminal, navigate into the **BT/Linux** folder of the extracted **.zip** file
- Run the following command:
sudo make install INTERFACE=usb
](https://www.edimax.com/edimax/download/download/data/edimax/global/download/bluetooth/ew-7611ulb_v2)](https://forums.developer.nvidia.com/t/edimax-ew-78111un-v2-wifi-setup/165047/13)
thank you!! very much helped
