Greetings,
I have set up a 5V power supply which is powered by a 9VDC 650mA wallwart.
I have a green led plugged in which lights up when the power switch is on.
I have connected the DS18B20 as follows:
pin 1 - GND
pin 2 - PD6 (pin 12 of the atmega168)
pin 3 - 5V rail
I have also connected a 4.7k resistor between pin 2 and 3.
When I flip the power switch on, the green led turns on and slowly dims out.
When i unplug the DS18B20, the led stays on.
Is the DS18B20 using too much power?
Best regards,
Chris
