I am using eagle pcb and I would like to have 4 holes for screws. I have seen on pcbs a small copper or silver pad that surrounds the hole meant for a screw to make contact with it. I have been able to create the hole in eagle and it seems to show up when i design it but when i send it to my manufacturer (gold phoenix) i get a hole with copper on the inside of the hole and not around the hole on the top and bottom layers. Any ideas how I can fix this? Thanks!
HakBot:
Hello,I have seen on pcbs a small copper or silver pad that surrounds the hole meant for a screw to make contact with it. I have been able to create the hole in eagle and it seems to show up when i design it but when i send it to my manufacturer (gold phoenix) i get a hole with copper on the inside of the hole and not around the hole on the top and bottom layers.
It would be helpful if you can
post your EAGLE design files here (or PM me).
The PCB artwork in EAGLE needs a schematic component
called “mounting hole” for each instance of the holes with
pads on your PCB. You may wish to connect these mounting
holes to your PCB’s common or ground net, or leave them
floating. Your EAGLE library should include holes.lbr
