I have a circuit that has repetitive designs. How can I pattern this without rerouting every single block? I tried copy, cut and paste, but I cannot get it to work without consistency errors.
Try this:
“Group” command (the dashed rectangle),
Then the “Cut” command (the scissors below group),
Then Ctrl + Right-Click,
Followed by the “Paste” command (the highlighter to the right of cut)
An issue with the above method is as follows:
If a net is named ending with $ followed by a number, Eagle will automatically increment the number as long as the wire isn’t Labelled. So make sure to Label any net that you don’t want incremented, and delete the Label on any net you want incremented
