I am building a 8 channel LED driver right now. It has 8 iterations of a http://diodes.com/zetex/_pdfs/3.0/pdf/zxld1360.pdf buck LED driver with a PIC18F2520 on a PCB. I am using Eagle for this because Eagle rocks. Is there a way to make the LED driver schematic/layout one time and then copy it. I can copy the schematic as a group, but then have to manually fix the layout each time. Is there a simpler method? Thanks in advance.
- joseph Y.
