How to layout 3 idenitical circuits in Eagle
Hi all. I have a project that requires 3 separate channels of analog amplifiers. I can create a schematic for one channel and copy it twice more to get all three channels. Eagle nicely takes care of the part numbers. How can I do the same thing on the board layout?
That is how can I lay out one channel and then copy that to the other two so they are all identical?
Thanks, Ed.
I dont think its possible to dupe board layouts in eagle.
Gerbmerge is a python script that can tile gerbers. If each channel can be its own separate circuit then that would work for you but if they are all shearing something like a common power supply it would be more tricky to get gerbmerge to do what you want.
If there is a way to do it in eagle I would love to know about it too.
I did some ULP/python/SCRIPT hackery to make that work once, but it was just a hack.
I’ve since stopped using Eagle.
–David Carne
It’s not perfect but I think if you follow the steps I posted here:
viewtopic.php?t=19087
it will work.
I tried it and it works fine! Thanks Loads, Ed. :smiley:
