tiling
still learning eagle, much different than protel. is there a way to tile boards in eagle? i hate using third party tiling programs that dont work
liquidemmy:
By tiling, I assume you mean panelizing - placing multiple copies of a given layout on a single board (aka panel). there is no good way to do it with eagle, you could lay out multiple copies but that is problematic if you make changes.
You should check out gerbmerge. It’s really well done and it’s free. You need to have python (also free) and its a bit confusing to set up (no installer) but once you have it set up it is really easy to use. I use batch files to hide the verbose command line invocation.
