Greetings - just wondering - you have a good set of additions to the eagle.scr file (and others) supporting your guidelines. I noticed though that in the Eagle 6.5 release notes, they seem to be encouraging moving shortcuts etc. out of the ‘eagle.scr’ file and into the ‘default-assign.scr’ file ( Default assignment of shortcuts moved from ‘eagle.scr’ to extra script ‘default-assign.scr’ to avoid undesired overwriting. The existing ‘eagleassign.scr’, which contains useful ULP shortcuts for library editing, has been renamed to ‘lbrassign.scr’. ) Are there plans to change your files on github to go along with that or are they going to stay the way they are. It was not clear to me if I would be best copying the eagle.scr file contents from github and inserting it instead into the ‘default-assign.scr’ file. Just curious as to what other people think.
mikey
