I’ve gone over all the tutorials online and tried everything but when i create a new device everything works (the symbol’s there i can use it in the schematic editor and it’ll switch the related package to the board editor) but when i place nets (electrical connections in the schematic editor) they won’t switch to the board,Any ideas? Thanks
Un-named (no name given)
make sure to create your board from the schematic…also have it open when doing any editing of the schematic.
Make sure your “airwires” layer is on…this is the connection points of the components until the board has been routed and totally connected.
Then you have to “route” the board for all of the traces to be placed.
Other than that…I’ve never had that problem.
Someone else may be of help.
James L
Draconicneo:
Greetings (no name supplied),
There could be several reasons for this to happen. Can you post the part you created? We can probably identify your problem with your library part and schematic files.
Comments Welcome!
