Hello, I need printed or PDF documentation for Eagles library ref-packages.lbr so I can easily match component packages without having to deal with the scaling problems in the Eagle library navigator and having to scroll thru endless lists (too time consuming).
I have found the ULP scripts showlbr_brd.ulp and showlbr.ulp at cadsoftusa.com but they fail to produce any output. I guess that could be due to that I have the demo version installed on this machine. One of the scripts also complain that a program.lbr is missing (it is).
Could someone run those scripts and make documentation on the most iportant libraries available?
Alternatively please advice if an Eagle library booklet is available.
LB3HC
Norway
