Eagle Library Problem
I made a new part and it looks fine. The problem comes up when I am in the PCB and I try to move the part. I must have missed something when I made the part because it won’t let me move it in my PCB. It will let me move it in the schematic, though.
It is a simple membrane type button pad - like the ones in the sparkfun lib except this one is bigger.
Kevin
I am assuming you moved your part too far away from the origin location. The origin is the little crosshair on top of the part that you see on the board. This is the place you actually grab to move the part around. I’m thinking the origin cross hair is somewhere away from the actual footprint.
You can see how removing the origin points effects being able to move the parts around by turning off the origin layers.
I feel like a moron! I shut off most of the layers (including Origins)… I turned them back on and it works!
Thanks a million!
Kevin
