Eagle SMD layers
Is it possible to put an SMD component on the bottom layer in eagle? if so how? i cant seem to figure it out
Hi Chupa,
Place it as normal, but while you’re moving it click on the ‘Mirror’ icon (looks like a 2x2 grid with half the squares shaded on the left side). That will automatically flip the part and place it on the bottom layer.
(Knowledge ascertained from the sparkfun tutorials!)
ha i was just comming here to say i found my answer here viewtopic.php?p=29899&sid=f8db502f1a7da … 114a01640b
i normally keep the sparkfun tutorial open in a window when im working to use as a reference. i dident realize you could use the mirror thing for components as well as txt.
thanks silic0re!
