I’m sure this is a really simple one, but I can’t find the answer in the Eagle manual, or online.
I have a 2-layer PCB, created in the free edition, which I want to add a wire link to. I can’t figure out how to do this (without leaving a wire partially unrouted).
Could someone point me in the right direction, please?
Tom
PS1: by wire link, I mean simply a piece of wire linking two pads; effectively a zero-ohm resistor - is there another term for this?
PS2: is it me, or is the Eagle manual great once you know the specific keyword they use, and hopeless until that point?
Thanks! That did it, although I was hoping for a technique that didn’t require a change to the schematic (Eagle won’t let me just drop the part on to the board, claiming it can’t back annotate).
When you’re just working on a 1 layer PCB, or if you have the pro version, I usually put the wire link in as a track on another layer. Then the vias appear for you to solder the wire to.
henryhallam:
you will probably want to increase the size of the vias if you do that.
note, this will require special instructions if you have the board made by a vendor though I assume you are making the pcb yourself.
