Using EasyVR Commander, I have added commands, trained and tested them with no problems. I can speak into the mic and all commands are recognized. Moving on to the next step, I am now trying to do some basic testing using Arduino. I am using the following code
// compiles clean //
Code to use the EasyVR shield to control a 230v light.
To use this code, download the EasyVR library first.
http://www.veear.eu/downloads/
This code is based on an example-code made by Veear and is used in the Mikelab series on YouTube
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#include "SoftwareSerial.h"
SoftwareSerial port(12,13);
#else // Arduino 0022 - use modified NewSoftSerial
#include "WProgram.h"
#include "NewSoftSerial.h"
NewSoftSerial port(12,13);
#endif
#include "EasyVR.h"
#define SND_BEEP 0
EasyVR easyvr(port);
EasyVRBridge bridge;
uint32_t mask = 0;
int8_t group = 0;
uint8_t train = 0;
char name[32];
boolean onestat = true;
boolean twostat = true;
boolean threestat = true;
boolean fivestat = true;
boolean sixstat = true;
void setup()
pinMode(6,OUTPUT);
digitalWrite(6,LOW);
// bridge mode?
if (bridge.check())
cli();
bridge.loop(0, 1, 12, 13);
Serial.begin(9600);
port.begin(9600);
if (!easyvr.detect())
Serial.println("EasyVR not detected!");
for (;;);
easyvr.setPinOutput(EasyVR::IO1, LOW);
Serial.println("EasyVR detected!");
easyvr.setTimeout(5);
easyvr.setLanguage(EasyVR::ITALIAN);
int16_t count = 0;
if (easyvr.getGroupMask(mask)) // get trained user names and passwords
Serial.print("mask= ");
Serial.println(mask,BIN);
for (group = 0; group <= EasyVR::PASSWORD; ++group)
if (group == EasyVR::TRIGGER)
Serial.print("Trigger: ");
else if (group == EasyVR::PASSWORD)
Serial.print("Password: ");
else
Serial.print("Group ");
Serial.print(group);
Serial.print(": ");
count = easyvr.getCommandCount(group);
Serial.println(count);
for (int8_t idx = 0; idx < count; ++idx)
if (easyvr.dumpCommand(group, idx, name, train))
Serial.print(idx);
Serial.print(" = ");
Serial.print(name);
Serial.print(", Trained ");
Serial.print(train, DEC);
if (!easyvr.isConflict())
Serial.println(" Times, OK");
else
int8_t confl = easyvr.getWord();
if (confl >= 0);
else
confl = easyvr.getCommand();
Serial.println(confl);
void loop()
begin:
int idx_cmd;
easyvr.setPinOutput(EasyVR::IO1, HIGH); // LED on (listening)
Serial.println("Say a command in group two");
easyvr.recognizeCommand(2); // recognise command in group 2
while (!easyvr.hasFinished());
easyvr.setPinOutput(EasyVR::IO1, LOW); // LED off
delay(3000);
idx_cmd = easyvr.getCommand();
if (idx_cmd >= 0)
Serial.print("Name: ");
if (easyvr.dumpCommand(1, idx_cmd, name, train))
Serial.println(name);
Serial.println(idx_cmd);
else
Serial.println();
if (idx_cmd == 2){
if(onestat == 0){
onestat = 1;
Serial.println("Lights turned on!");
easyvr.playSound(SND_BEEP , EasyVR::VOL_FULL);
goto begin;
else{
onestat = 0;
Serial.println("Lights turned off!");
goto begin;
else
if (easyvr.isTimeout())
Serial.println("Timed out... try again!");
int16_t err = easyvr.getError();
if (err >= 0)
Serial.print("Error ");
Serial.println(err, HEX);
When running this I get the following on the monitor
Sound table: n/a
Custom Grammars: n/a
Group 2 has 7 command(s)
0 = OK, Trained 2 times, OK
1 = WAKEUP, Trained 2 times, OK
2 = BEGIN, Trained 2 times, OK
3 = SMILE, Trained 2 times, OK
4 = BE_HAPPY, Trained 2 times, OK
5 = STOP, Trained 2 times, OK
6 = SHOW, Trained 2 times, OK
Say a command in Group 0
Timed out, try again…
I’m using exactly the same setup with the shield and microphone as I used with the commander and I cannot get easyVR to recognize anything. Have tried many times.
Need help to move forward.
