EasyVR with shield 3
Hi all! I have few questions about the easyvr and shield. Ive got it soldered and stacked on an Uno, ive gone through Commander to create my trigger word which is “ON” and add a few commands in group 1. When I generated the code into aurdino and uploaded the sketch I have multiple digital pins that are High all the time, digital pin 13 for example, is the shield using digital pins to run? Also my action code for my trigger word fires with all of my custom commands for some reason, is there any example files I could reference to code my trigger and and switch my group? I googled and havent been lucky in my search. I declared my pins as outputs and used the digitalwrite with a delay and it works but it fires with any command. Any guidance would be appreciated!
From the [users manual, it looks like pins 0,1,8,9,12, and 13 are all used by the shield. You might be able to reassign those through jumpers though.](https://cdn.sparkfun.com/assets/learn_tutorials/9/3/1/EasyVR-3-User-Manual-1.0.17.pdf)
Thanks Yellowdog! I must have skimmed over that in the manual. Any chance you know of any example projects or tutorials on this, like switching groups and the actions for each learned command?
Sorry, I don’t. I’ve never actually used this part before but thought it looked interesting from your post and had a quick look at the manual. You probably know more about it than me at this point! :lol:
lol dannngggg
