Project description:
My topic is digital faith, how is the digital changing the way we believe?Will our faith continue to exist in a more digital age, and will people create new digital gods? Or make a pilgrimage to a digital screen?
I made up a digital Buddha.Insert the electronic incense into the incense burner, and the machine will print the result of your request.
Video:
Parts, Tools, Supplies:
Arduino uno/ Print module / Power supply 12v /Photoelectric module/ Soldering iron & solder / Wire strippers/ USB A-B cable/Dupont wire
Production process:
Design the shape of electronic Buddha and Incantation paper,and make each part of the entity
Welding screen and put the electronic Buddha on my screen
Weld each part according to the circuit diagram(connected each component (Photoelectric module and Print module) to the circuit board with wires respectively)
Enter the code
Debug the picture code and debug its rendering effect in the print module
Test the code
Upload the final code
Use wood to make boxes for sticking incense and to make boxes for printing parts
Assemble the circuit into the case of each component
Instructable link:
