EMG v3 sensor
I connect the EMG v3 sensor to its correct connections with nine volt batteries and pca9685 servo drive with a five volt 30 amp power supply and it gives the highest value 1023.
When I disconnect the power supply, the sensor works properly
What is the problem ?
And I needed the power supply in the delivery, I did not dispense with it…
wekamohamed2353@gmail.com
I think you’ll get more responses if you kindly share your circuit diagram.
