ENC28J60 Schematic
I want to build a ENC28J60 board. The problem comes in the schematic:
http://img24.imageshack.us/img24/75/schqma.png
Wich value has L1???
I already know that R2 depends of chip revision.
If anyone can help me… THANKS!!!
Have you tried the ENC28J60 docs?
Leon
leon_heller:
Leon
Of course, only that says is:
Ferrite Bead should be rated for at least 80 mA.
http://img203.imageshack.us/img203/8114/esquema.png
Thanks for your answer.
That’s all you need to know. It’s just a ferrite bead with a wire through it, you can make it yourself or buy an SMD one. It’s only an EMI filter circuit, it will work OK without it.
Leon
Sorry, but I don’t know so much about electronic so I’ll buy it. I need to know henries, don’t I?
Thank you very, very much.
The inductance isn’t relevant. Just use a ferrite bead with a wire through it.
Leon
leon_heller:
Leon
Hi!
I’m using this: http://parts.digikey.com/1/parts/121287 … 79267.html
Works perfectly with the ENC28J60 in my project.
regards,
Peter
I can’t stand how some people use an inductor symbol for ferrite beads. Stupid.
NleahciM:
At work we have debated what the schematic symbol for a ferrite bead should be. In our CAD library we have symbols that look like an inductor, a rectangle with pins and a inductor and resistor in series inside a rectangle. Modeling a ferrite bead in spice it’ll look like an inductor and resistor in series.
What are your recommendations for a schematic symbol for a ferrite bead?
I don’t seem to have one in my CAD library. If I create one I’ll probably use an inductor symbol with FB as the part name. Another one I’ve seen is a rectangle at 45 degrees, which might be better, as it looks a bit like the component.
Leon
lol i use a resistor symbol and label em FBx
same footprint so it was logical and quick.
