Error. Starting PostCard without Bluetooth
Did it work again without re-flashing, or did you have to re-flash FW again?
I flashed it twice. I think the problems appear when I change the operating frequency. It comes with 2 Hz and I set it to 5 Hz, and I also changed some NMEA messages.
Just commenting.
Now, after updating again to v2.1 and the LG290P to the latest firmware, I have Bluetooth and everything seems normal, but I can’t see any satellites. I’m trying a cheap antenna that worked until yesterday. The small helical antenna will arrive on Saturday, or so I think.
The truth is, I’ve played a lot with a Facet and didn’t have as much trouble as with this little board.
If you can think of anything to explain why I can’t see satellites when everything seems properly connected, I’d appreciate it.
Postcard RTK. Fails with Bluetooth blocked and Wi-Fi configuration error
I’ve continued to have problems with the reboot, where sometimes Bluetooth doesn’t turn on.
I’m looking for a connection with some configuration changes I’ve been making.
I noticed that despite having the Wi-Fi configuration set to AP mode, it doesn’t activate in AP mode. Instead, it switches to Wi-Fi mode and connects to my home router.
In general, the problems I’ve had with Bluetooth being blocked have been with attempts to configure it through Wi-Fi configuration.
I’m still trying to find the connection between variables.
Does anyone see the problem?
