Probably with the following hints
I think I will do it.
If you know anything about this
please tell me. (I have also contacted the manufacturer, but I have not received any contact.)
Your board manager below
https://raw.githubusercontent.com/spark … index.json
When you add
I got it probably
Arduino official sample
iothub_ll_telemetry_sample
→ Cannot compile
It is said that blob.h does not exist
A person’s GITHUB presented a solution
It is the same in practice.
From here
https://github.com/Azure/azure-iot-pal-arduino/issues/9
Is there any other solution?
please tell me.
Current status of the problem
What should I do to solve the next problem?
please tell me.
I don’t know how to use AZURE IOT HUB
“AZUREIOTPROTOCOL_HTTP”
https://www.arduinolibraries.info/libra … tocol_http
Even if I download the above, I do not understand the contents of the header file that was there
I don’t know how to transfer
I don’t know how to communicate via HTTP.
Contents
Even if I download it, I do not understand the contents of the following source
#ifndef AZUREIOTPROTOCOLHTTP_H
#define AZUREIOTPROTOCOLHTTP_H
Please tell me about the above.
Official sample
→ Cannot compile
From here
