Hi all,
I’m creating a Matter-based air quality sensor and have successfully adapted the MatterLightOverThread sample to publish dummy temperature data that is visible in the Google Home app. I thought this would be the hardest part but proved not too difficult.
What I thought would be the easy part was reading data from a connected I2C temperature sensor (SHT3X). However, going through both the Sparkfun and Silicon Matter sites, I don’t see a straightforward example of doing this. I’ve found references to example I2C code that connects two boards together via I2C and sends data back and forth (https://github.com/SiliconLabs/peripher … main_efr.c) but even this requires porting to fully compile on the Thing Plus Matter’s MGM240P which I thus far haven’t been fully successful in doing.
Is there a simple example somewhere for how to read data from an I2C device using the Thing Plus Matter? Given its Qwiic connector, this seems like it should be a pretty common use case?
Thanks in advance for any guidance or pointers.
