FLIR Lepton 3.5 on breakout v2.0 — VoSPI loses sync after minutes / works only when pressed (I²C always fine)
Hi all — hoping someone here has seen this one. I’ve narrowed it down with some systematic testing (below) but wanted to check with the community before swapping hardware.
HARDWARE
  • Breakout: FLIR Lepton Breakout Board v2.0 (marking 250-0577 REV-110), bought from
    SparkFun as the Radiometric Lepton Dev Kit
  • Sensor: FLIR Lepton 3.5 (radiometric)
  • Host: Raspberry Pi 4, Raspberry Pi OS
  • Interface: SPI on spidev0.0 (CE0), SPI mode 3, 16 MHz; I2C (CCI) on bus 1
SYMPTOM
On a cold start, VoSPI syncs perfectly and streams clean radiometric frames (sensible
degC). After a few minutes it loses VoSPI sync and will NOT recover on its own
(re-opening SPI / long CS de-assert doesn’t help) — only a power-off cooldown or
physically reseating the module restores it. Throughout, I2C (CCI) NEVER drops — the
module answers at 0x2a the whole time, even while VoSPI is dead. The sensor produces
perfect frames whenever it IS synced, so the sensor core looks healthy.
This looks a lot like the “works only when I press the module with my thumb” report in
this thread: community.sparkfun.com/t/.../68558 — where the conclusion was a module not
fully seated / a broken socket-holder.
SYSTEMATIC TESTING (time-to-failure per condition)
  1. No fan, cold start … synced, failed after ~10-17 min (desync loop)
  2. Fan aimed ON the breakout … synced, failed after ~5 min (FASTER - vibration)
  3. Fan aimed side-on to the pins . synced, failed after ~9 min (hard hang)
  4. Software restart while warm … would NOT re-sync at all until a power-off cooldown
  • Active cooling did NOT help (and failed faster with the fan ON the board), so the
    trigger seems mechanical (vibration-sensitive marginal contact), not pure thermal.
  • Two distinct failure modes: a VoSPI desync-retry loop, and a hard hang in the SPI read.
ALREADY RULED OUT
  • Power: Pi ‘vcgencmd get_throttled’ = 0x0 (no undervoltage) on a proper 5V/3A supply
  • Wiring/mapping: continuity verified pad->Pi on all SPI lines; mapping correct
    (SCK/MISO/MOSI/CS); checked for bridges/shorts to neighbors and to GND/3.3V
  • Wiring method: multiple Dupont jumper sets, fresh jumpers, AND soldered — same behavior
  • SPI clock: tested 16/12/10/8/6/4 MHz — lowering it does not help
  • I reseated the module correctly (all 3 clips, square) many times — still marginal
QUESTIONS
  1. Is this a known marginal-contact issue at the Lepton module-to-socket interface on
    this breakout, or a trace/joint on the board itself?
  2. Given reseating many times doesn’t fix it, does this point to a bad socket/holder?
  3. Anyone found a fix, or is a replacement breakout the answer?
(Side note for anyone searching: the I2C-stays-up-while-16MHz-VoSPI-dies pattern is the
tell — a contact that’s fine for slow I2C can be fatal to fast SPI.)
  1. Not generally…given your symptoms it could be either one (board’s socket or FLIR’s pins) that is causing it
  2. Very likely
  3. Sometimes you can tape it in-place if you find a working angle/situation
Is this the unit from 2019 (I poked through your orders)? If so, it might help to to-oxidize the pins (especially on the breakout side)
Thank You for the feedback.
I tried De-Oxidixe and use the taping it. However, it still does not work after 3-4 minutes now.
@TS-Russell any feedback?
It sounds like one or the other has become faulty - is this the one from 2019?
@TS-Russell Thanks for the reply. They are from 2019.
Gotcha (I was asking in case warranty was a consideration)
I’d first try replacing the breakout as it is considerably more wallet friendly (compatible with Lepton 3.5) than replacing the Lepton
