Follow-Up Question: Wire Splice Reliability and Enclosure Design for Raspberry Pi Installations
Hello everyone,
This is a follow-up question related to my Raspberry Pi monitoring project.
While investigating the electronics and software side, I’ve also started reviewing installation and maintenance considerations. The final system will be installed in locations where power cables, sensors, and communication wiring may need servicing over time.
Because of this, I’m evaluating different wire splice methods and cable-management approaches to improve long-term reliability.
Questions:
  1. What ) have proven most reliable in permanent Raspberry Pi installations?
  2. Do you generally prefer crimp splices, soldered splices, heat-shrink butt splices, or lever-style connectors?
  3. Have you experienced failures caused by vibration, humidity, or temperature changes?
  4. What practices have worked best for balancing serviceability and reliability?
Mechanical Enclosure Question:
The electronics will eventually be housed in a custom enclosure with cable routing, ventilation, and maintenance access. I’m currently evaluating CNC-machined and rapid-prototyped enclosure options ). (Guide here please)
For those who have deployed Raspberry Pi-based systems:
  • What enclosure-related mistakes caused the most rework during early revisions?
  • How much extra space do you typically reserve for cable routing and future maintenance?
  • Have thermal issues become a concern once the Raspberry Pi was enclosed?
  • Any recommendations regarding airflow, mounting methods, or long-term durability?
I’d appreciate hearing from anyone who has taken Raspberry Pi projects from prototype stage into real-world deployments and learned some lessons along the way.
  1. Depends on what’ll be happening to it (temperature, humidity, vibration, etc). For auto you prefer
  2. Soldered for most things, wago-style for professionalism
  3. Of course…mounting and environmental mitigation can be a challenge, will always depend on your use-case
  4. Have spares pre-programmed and know where they are/will need go…this is easy with a central backup and a few SD cards if you’d prefer on-the-fly (saves cost)
