Raspberry Pi 4 complete Desktop kit
It is too bad that the 40-pin female GPIO Bridge connector will not fit onto the Raspberry Pi 4’s PCB male header after the heatsink assembly is installed.
Looks like the aluminum case section around the header could have easily been machined wide enough to allow this, but alas, it was not in my case.
A hack saw or angle grinder will fix that problem really quick. :wink:
