Is there a Fritzing part diagram for the Artemis ATP? If not, is there a closely related part I can edit? Thanks
While we don’t have a fritzing diagram, you can check out the pinout map here https://cdn.sparkfun.com/assets/8/2/3/3 … apping.pdf and the hookup guide here https://learn.sparkfun.com/tutorials/ho … 1615791300 that should have enough info to get ya goin’.
Best of luck!
Thanks. It’s been provided on the Frizing forum here: https://forum.fritzing.org/t/sparkfun-artemis-atp/13280
Is there a reason why Sparkfun boards aren’t in the Sparkfun library in Fritzing?
Mostly time constraints, there are a limited number of people to create those models and they have lots of other job responsibilities. ![]()
Understood. Thank you.
