FT2232D IC
Hi ,
I was wondering if SFE is planning to stock the FTDI USB to (2X) RS232 IC?
Also i don’t know if this is the right place to ask but can i use any of the standard SFE FT232RL Break out boards for making a USB to RS485 converter.
thanks
ksamay:
Hi ,
thanks
yes you can use a max485(half duplex) or max488(full duplex) to make the conversion…
I got both the chips, could you suggest a suitable circuit diagram ?
ksamay:
The datasheets for each should show you normal application circuits, which should work fine for your purposes.
Hello friend, it is good think.
ksamay:
Hi ,
thanks
Hi ksamay…
I just posted a schematic for a TTL version of RS485 over [here.
It’s not ready for primetime and it’s not quite RS485, but it might give you a starting point.
(I assume this is for Dynamixels, since I’ve seen your screen name on Robosavvy.)
Cheers,
Pete.](http://forum.sparkfun.com/viewtopic.php?t=13107)
Hi Petej,
Thanks, your schematic is a great starting point.
yup , its for a dynamixel ( RX series ).
I am planning to make a custom converter board for use with a gumstix board on my (future) humanoid.
I read in a thread on Robosavvy that latency is a issue with the Rs485 line. so i was thinking if i divide my bus into two and use the 2 serial outputs on the new FT2232D IC and convert them to Rs485 individually. it might reduce send time by half!
But , i am not able to find FT2232D online ( i.e cheap and small quantity ).
RS stocks them:
http://uk.rs-online.com/web/
Leon
