FTDI breakout board with Robertsonics wav trigger connection issue
Could somebody suggest how I might get my WT config to recognise the wav trigger board using a FTDI breakout board? I have looked in system information and it does not show up on any USB port.
I am running OS Big Sur 11.4 on a 2017 iMac retina 4K
The wav trigger works perfectly using the SD card.
Robert sonics configurator version 2.00 beta 2
What am I missing?
Hello, which FTDI board are you using? And what is the connection that you’re making between these two?
