Yes, the GM862 has a SIM card holder built-in, push-lock/push-eject. The Eagle footprint indicates the location of the slot IIRC.
I’ve spun several boards around this part and it works well. One thing to watch out for is any parts/vias/traces you might have on your board under the antenna connectors. If the antenna cables can rotate, the connectors may hit the board and cause a short.
