I am using GM862 with the evaluation kit EVK3 USB version…when i programme it,it will automatic turn off by itself >.<
I alrdy plug in an adapter with 4.5v supply and the USB port i plug at the port at the behind of the CPU…theorectically it should be enough power to run it…but it still will turn off…(this is only happend when i m using it either through Rsterm or Hyperterminal,if I on it and just leave it there it wun turn off…)any1 help pls???
-KeNshIn-
