GM862-GPS as a location reporting device via SMS
Hi people, I’m currently doing a university project. I would like to build a device that sends out it’s current gps location via sms to a designated cell phone number. So far I think GM862-GPS module looks like the most promising piece of component I can use. I’ve been searching around the internet the past couple of day for more info on how i can go about building this device. Can anyone here with any idea give me some advice. Deeply appreciated it.
For documentation on the Telit GM862-GPS try the [Telit website
AT Command reference - http://www.telit.co.it/data/uploads_EN/ … _r2(1).pdf
[Easy Script in Python](http://www.telit.co.it/data/uploads_EN/products//80000ST10020a_Easy%20Script%20in%20Python_r2.pdf)](http://www.telit.co.it/down.asp?productId=105)
You can use this the send the sms, you just need to format you GPS sentence then call the function to send your sms.
def SendSMS(phone_number,sms_text):
print ‘made it to def’
res = MDM.send(‘AT+CMGS=’+ phone_number + ‘\r’,5)
n=0
while n < 20:
res=MDM.receive(1)
if res.find(“>”) >-1:
print n
break
else:
n = n +1
res = MDM.send(sms_text, 10)
if res != -1:
print ‘Text sent ok’
res = MDM.sendbyte(0x1a,10)
n=0
while n < 20:
res=MDM.receive(1)
if res.find(“+CMGS”) >-1:
print n
break
if res.find(“ERROR”)>-1:
print ‘sms ok’
else:
print ‘not good’
else:
n = n +1
print ‘def completed *******************’
indented version can be found here http://www.mitech-es.com/newbihelp.txt just copy and paste.
Hope it helps.
How easy is it to turn one of these into a small tracking device - what else is required?
Read the datasheet posted above.
At the minimum, a GPS patch antenna, a GSM antenna and a battery of some sort.
now is there a way to do that but via GPRS? if anyone can help please?
If you read the ‘Easy GPRS’ doc at http://www.roundsolutions.co.uk/techdocs
you can also search their forum for the information you require, if you post on their forum you need a customer number before you get help but you should find everything you need without having to ask.
I have my new devices turning up on Tuesday, I will post a pic when they arrive.
