GM862-RS232 Eval board
Hi
Can I use the GM862 Python module with this board? I mean will I be able to get the script to run because I’m under the impression that you need a full serial port (all signals) for it to work. And I see on the schematic that this board doesn’t implement all signals. Or can I get the script to run using only Tx, Rx, CTS, RTS and controlling DTR manually with that switch?
RH
