Does Spark Fun produce a receiver (1m-2m accuracy) for sending GGA and ZDA NMEA strings via a data cable connection?
Sure, we have many options…basically any of our u-blox modules will have that accuracy (or MUCH better! some are ~1.4cm accuracy)
I’d recommend this one https://www.sparkfun.com/products/15712 as a less expensive option (1.5m accuracy, USB port for easy config of messages), and maybe https://www.sparkfun.com/products/18443 for a higher-end module
You can send the data over many protocols for either (i2c, SPI, UART)…here’s an overview for the M9N https://learn.sparkfun.com/tutorials/sp … e-overview
Thank You. Can you answer my other post? Here: viewtopic.php?f=74&t=61180
Also, would any of these send GGA and ZDA strings? They are ublox gnss boards.
Neo-M8n GPS w compass by Holybro
Mateksys SAM-M8Q Gallelio GLONASS module
