What cable type (RG161, 0.086” flex, etc) the 1m coax cable is on the GPS-14987-ND GPS/GNSS Embedded Antenna – 1m?
Thanks ![]()
Thanks ![]()
FYI sparkfun, the datasheet link is broken.
Thanks; should be fixed shortly
In the meantime…the datasheet doesn’t list the cable’s specs https://mm.digikey.com/Volume0/opasdata … 87_Web.pdf
