I recently purchased your weather shield and everything works except the GPS (735T). I tried the code listed and still no results. The libraries are installed and I get no errors with compilation. I am unable to find a similar thread on the forum.
Could be that your GPS isn’t getting a signal.
Are you in a building when you’re testing our outside?
No luck outside. I tried it for 15 min and no satellites were reported. Interestingly I tried my older board and GPS which worked fine and it also reported no satellites. I am stumped.
TS-Chris:
Could be that your GPS isn’t getting a signal.Are you in a building when you’re testing our outside?
I have tried it outside to no avail. OTHER THOUGHTS?
