GPS-RTK2 Base and Rover
How could I connect two GPS-RTK2 modules one as a base and another as a rover?
Which RF module would be appropriate for a distance of 1km ?
Is there any way of doing a direct cable test between the two boards?
Best regards
Please see the tutorials below for help with your question.
  • - [[GPS-RTK Hookup Guide](https://learn.sparkfun.com/tutorials/gps-rtk-hookup-guide)
  • - [[GPS-RTK2 Hookup Guide](https://learn.sparkfun.com/tutorials/gps-rtk2-hookup-guide)
  • [/list]
    That can be tricky and you will need to test different RF modules and antennas to find a combination that works for your setup. If you need 1km range, look for modules that have double or triple that range for best results.
    Yes, just feed the output from be base to the input of the rover.](https://learn.sparkfun.com/tutorials/gps-rtk2-hookup-guide)](https://learn.sparkfun.com/tutorials/gps-rtk-hookup-guide)
