I wonder if It’s possible to use GPS-RTK2 Board without GPS/GNSS antenna?
If the antenna is necessary, can I use a chip antenna, for example the one below
https://www.sparkfun.com/products/15247
Thanks in advance!
Thanks in advance!
Hello!
Unfortunately an active antenna is required for these to work and our passive antennas are not compatible. The following antennas will work just fine with our RTK GPS boards:
Thanks a lot for the quick reply!
We hope to use GPS-RTK2 in a wearable device, is it possible to make the anntenna smaller?
TS-Chris:
Hello!Unfortunately an active antenna is required for these to work and our passive antennas are not compatible. The following antennas will work just fine with our RTK GPS boards:
- GPS-14986 - GPS-14987 - GPS-15192
You might be able to find a smaller antenna, but unfortunately the three choices above are the smallest antennas we carry that still work with a RTK GPS.
