gps-rtk2 board -zed-f9p
Hi
Im Pandiarajan, from India.
we have our own company (INDOGEO CONSULTANCY PRIVATE LIMITED) and we are doing geological services.
we are interested to make our own DGPS for our survey purpose.
can you suggest us to purchase the gps-rtk2 board -zed-f9p and is it working properly in our region?
kindly reply me.
thank you,
Pandiarajan, Managing Director,
INDOGEO CONSULTANCY PRIVATE LIMITED.
Hi Pandiarajan.
The ZED-F9P should work anywhere in the world where you’re able to receive GPS signals.
Thank you for your reply. Im interested and I need suggestion to buy accessories with ZED-F9P.
Im already have Arduino uno and Raspberry pi4 boards.
You might have a look at our [hookup guide, for full details, but at a minimum you’re going to need an antenna and a way to connect it to the board.
[GPS-15192 is the recommended antenna and [WRL-09145 is the cable you need to connect the antenna to the board.](Interface Cable SMA to U.FL - 100mm - WRL-09145 - SparkFun Electronics)](GNSS L1/L2 Multi-Band Magnetic Mount Antenna - 5m (SMA) - GPS-15192 - SparkFun Electronics)](GPS-RTK2 Hookup Guide - SparkFun Learn)
Thank you for your suggessions.
PRESENTLY WE NEED SOME MORE SUGGESTION FROM YOUR SIDE TO INITIATE PURCHASE.
  1. DISPLAY AND DRIVER BOARD SUGGESTION FOR GPS-RTK2 BOARD -ZED-F9P MODULE (ANY UPDATE VERSION ALSO INTERESTED)
  2. COMPLETE DIY KIT FOR GPS- (GEOLOGICAL PURPOSE) OF 2.5 METER ACCURACY LEVEL AND LOW SIGNAL WORKING INBUILT ANTENNA WITH ACCESSORIES INCLUDE DISPLAY AND DRIVER MODULE.
WE AIMING TO MAKE OUR OWN DGPS AND GPS DIVICE FOR OUR GEOLOGICAL SURVEY PURPOSE. (APPROX OF 15-20 NUMBERS)
THANK YOU AND EXPECTING YOUR SUGGESTION.
PANDIARAJAN. R
MANAGING DIRECTOR,
INDIA.
You're going to need to come up with something that would work for your application, I'm afraid I don't have any suggestions.
  1. COMPLETE DIY KIT FOR GPS- (GEOLOGICAL PURPOSE) OF 2.5 METER ACCURACY LEVEL AND LOW SIGNAL WORKING INBUILT ANTENNA WITH ACCESSORIES INCLUDE DISPLAY AND DRIVER MODULE.
Unfortunately we don't carry a complete kit. This is something you will need to design on your own and then purchase the individual parts.
THANK YOU
PANDIARAJAN R
