What kind of range would be normal to measure when the accelerometer is operation in +/- 100gs mode, when the sensor is not moving, and when the sensor is at around 50 gs? I was hoping for around 0.1 g/s accuracy, but I’m not sure if that is possible.
Check out pages 9 & 14 in the product’s datasheet here https://cdn.sparkfun.com/assets/c/6/5/8 … 053090.pdf (link found under ‘documents’ tab on product page)
Hope this helps!
