Hard reset of Zigbee Module?
Is there a way to do a hardware reset of a Zigbee module to reset everything back to its factory defaults? The datasheet says
the reset pin does a “module reset”, but it doesn’t say whether it simply re-boots it, or if it resets everything back to its defaults.
I’m looking for a hardware reset, not a command to send to it.
I remember reading somewhere you can pull one of the data lines low for 5 seconds, but I can’t seem to find it anymore.
