I was wondering if anyone could recommend a header part that will fit the LPC-E2468STK board, and that a mere mortal like me can solder in place? :? Looks like 0.5mm spacing to me…
You mean the LPC-E2468, presumably.
Try Molex, but they might be something else. You really need to contact Olimex.
I’ve drag-soldered similar connectors without any problems.
Leon
Oops, you’re right - LPC-E2468!
I just measured it as 0.05"… so shouldn’t be hard to solder. Hunting for parts…
I ended up with Digi-Key part # A99320-ND
This is a female connector, 40 position, .050" SMD.
They have little plastic tabs that will snip right off.
