I realized I never updated my question with the answer. Note also:
For the Arduino IDE 3.3.x, put your custom CSV file in the same directory as your sketch.
The file must be named exactly: partitions.csv
In Arduino IDE: Go to Tools → Partition Scheme and select “Custom”
Build and upload. The IDE will automatically detect and use the partitions.csv in your sketch’s folder instead of the default one from the ESP32 package.
# partitions.csv — ESP32-C6 Custom Partition Table
# Target hardware : Arduino Nesso N1 (ESP32-C6, 16 MB flash)
# SparkFun ESP32-C6 Qwiic Pocket (4 MB flash)
# Flash mapped : First 4 MB (0x000000 – 0x3FFFFF)
# On the 16 MB Nesso N1 the remaining 12 MB is unused by
# this table — no partitions are defined beyond 0x3FFFFF.
# OTA capable : Yes — two equal-sized app slots (app0 / app1)
# Zigbee capable : Yes — three dedicated Zigbee stack partitions
# FULL FLASH MAP (including regions not defined in this table)
# Address range Size Name / role
# 0x000000 – 0x007FFF 32 KB Bootloader [NOT in table — hardcoded by IDF]
# 0x008000 – 0x008FFF 4 KB Partition table itself [NOT in table]
# 0x009000 – 0x00DFFF 20 KB nvs (NVS / Preferences)
# 0x00E000 – 0x00FFFF 8 KB otadata (active OTA slot selector)
# 0x010000 – 0x1BFFFF 1728 KB app0 (OTA slot 0 — factory / primary)
# 0x1C0000 – 0x36FFFF 1728 KB app1 (OTA slot 1 — OTA target)
# 0x370000 – 0x373FFF 16 KB zb_storage (Zigbee network data)
# 0x374000 – 0x374FFF 4 KB zb_fct (Zigbee factory config)
# 0x375000 – 0x378FFF 16 KB zb_nvram (Zigbee NVRAM / binding tables)
# 0x379000 – 0x3F4FFF 496 KB spiffs (SPIFFS filesystem)
# 0x3F5000 – 0x3FEFFF 40 KB coredump (crash dump storage)
# 0x3FF000 – 0x3FFFFF 4 KB phy_init (RF / PHY calibration data)
# TOTAL (partitions only) 4060 KB ← + 36 KB bootloader/table = 4096 KB
# = 4 MB (entire first bank)
# OTA SLOT SIZING NOTE
# Both app slots must be identical in size. 1728 KB (0x1B0000) was chosen to
# leave room for the Zigbee, SPIFFS, coredump, and phy_init partitions while
# keeping everything within the first 4 MB. The compiled sketch must be
# smaller than 1728 KB for OTA updates to succeed; Arduino IDE shows binary
# size after compile — check it against this limit.
# After a successful OTA upload, "otadata" is updated to point to the new
# slot. On the next boot the IDF bootloader reads "otadata", validates the
# new image, and launches it. If validation fails, it rolls back to the
# previous slot automatically.
# ZIGBEE PARTITION NOTE
# The ESP32-C6 Zigbee stack (esp-zigbee-sdk) requires exactly three
# FAT-typed partitions with these exact names. Renaming or removing any of
# them breaks Zigbee initialisation at runtime:
# zb_storage — Primary Zigbee NVS: network key, PAN ID, channel, device
# address table, neighbour table, and other stack state that
# must survive reboots. Zigbee.factoryReset() wipes this.
# zb_fct — Factory configuration written once at first join and used
# as the baseline for factory-reset restoration.
# zb_nvram — Secondary Zigbee NVRAM: binding table, group table, and
# additional stack state. Also wiped by Zigbee.factoryReset().
# All three use SubType "fat" so the Zigbee stack can use the FAT layer
# directly without going through the main NVS key-value store.
# Column reference
# Name — Partition label (max 16 chars); used by esp_partition_find()
# Type — "app" (executable) or "data" (everything else)
# SubType — Qualifies Type; see esp-idf docs for full list
# Offset — Byte address in flash; must be 4 KB-aligned (0x1000)
# App partitions must additionally be 64 KB-aligned (0x10000)
# Size — Partition size in bytes; must be a multiple of 4 KB (0x1000)
# Flags — Optional; "encrypted" to enable flash encryption for this slot
# Name, Type, SubType, Offset, Size, Flags
# ── System / NVS ─────────────────────────────────────────────────────────────
# Standard ESP-IDF NVS (Non-Volatile Storage) partition.
# Used by the Arduino Preferences library to persist settings across reboots:
# OTA mode flag, WiFi-mode flag, and the rapid-reboot OTA timestamp.
# 20 KB is the IDF-recommended minimum; larger is needed only if many
# Preferences namespaces are in use simultaneously.
nvs, data, nvs, 0x9000, 0x5000,
# ── OTA Bookkeeping ──────────────────────────────────────────────────────────
# OTA data partition — mandatory when using two OTA app slots.
# The IDF bootloader reads this 8 KB region to decide which app slot
# (app0 or app1) contains the currently valid firmware image. On a clean
# flash it is blank and the bootloader defaults to app0. After a successful
# OTA upload the Zigbee-side "zigbee-mode" reboot or ElegantOTA library
# updates this partition to point to the newly written slot.
# Must be exactly 8 KB (0x2000) and must sit at 0xE000 — both are IDF
# requirements.
otadata, data, ota, 0xE000, 0x2000,
# ── Application Slots (OTA) ──────────────────────────────────────────────────
# Two equal-sized OTA application slots — both must be the same size.
# The bootloader selects the active slot based on "otadata" above.
# app0 (OTA slot 0) — 1728 KB (0x1B0000)
# Factory / primary slot. This is where the sketch is written on first
# flash via USB. Must start at a 64 KB boundary (0x10000 is standard).
app0, app, ota_0, 0x10000, 0x1B0000,
# app1 (OTA slot 1) — 1728 KB (0x1B0000)
# OTA target slot. ElegantOTA writes the incoming firmware here while
# app0 continues running. Identical size to app0 is required; the IDF
# will reject an OTA image that is larger than the target slot.
app1, app, ota_1, 0x1C0000, 0x1B0000,
# ── Zigbee Stack Partitions ───────────────────────────────────────────────────
# Three FAT partitions required by the ESP32-C6 Zigbee stack.
# Names, types, and subtypes are fixed — the stack locates them by name.
# See ZIGBEE PARTITION NOTE in the header above for full details.
# zb_storage — 16 KB: primary Zigbee network state (NWK key, PAN, channel…)
# Wiped by Zigbee.factoryReset() to force a clean re-pair with the hub.
zb_storage, data, fat, 0x370000, 0x4000,
# zb_fct — 4 KB: Zigbee factory / calibration configuration (written once).
zb_fct, data, fat, 0x374000, 0x1000,
# zb_nvram — 16 KB: Zigbee binding table, group table, and additional NVRAM.
# Also wiped by Zigbee.factoryReset().
zb_nvram, data, fat, 0x375000, 0x4000,
# ── General-Purpose Filesystem ────────────────────────────────────────────────
# SPIFFS (SPI Flash File System) — 496 KB (0x7C000).
# Used by ElegantOTA and the web control panel (WiFi-only / OTA modes) to
# serve static assets. Also available for user configuration files or logs.
# SPIFFS has no subdirectory support; filenames are flat paths up to 32 chars.
# Alternative: replace with "LittleFS" (same SubType spelling in IDF >= 5.x).
spiffs, data, spiffs, 0x379000, 0x7C000,
# ── Crash Diagnostics ─────────────────────────────────────────────────────────
# Core dump partition — 40 KB (0xA000).
# When a crash occurs and core dump to flash is enabled in sdkconfig, the IDF
# exception handler serialises CPU registers, stack frames, and heap state
# here. Retrieve and decode post-mortem with:
# idf.py coredump-info (requires ELF with debug symbols)
# 40 KB is sufficient for single-core ESP32-C6 with a modest stack depth.
# This partition is never written during normal operation.
coredump, data, coredump,0x3F5000, 0xA000,
# ── RF Calibration Data ───────────────────────────────────────────────────────
# PHY init data — 4 KB (0x1000) at the very top of the 4 MB region.
# Contains RF calibration tables and PHY configuration used by the
# radio subsystem at boot. Written by the factory test process; the IDF
# reads it before initialising WiFi or the 802.15.4 (Zigbee) radio.
# 0x3FF000 is the standard IDF location — do not move this partition.
phy_init, data, phy, 0x3FF000, 0x1000,
