Help with Facet-L
I am unclear on how the facet works.
The guide says:
Every time the device is powered on the RTK Facet L-Band will attempt to connect to its ‘Home’ WiFi. If successful, the keys will be automatically be updated and stored. The whole process takes lass than 10 seconds (worst case). The RTK Facet L-Band will show a series screens indicating what its doing but the device is designed to be used without concern or supervision.
But the configuration page states that this will happen every time the key is older than 28 days and once a day.
So I got the first key, no problem and I could see the days the key was valid when re-starting the device.
The day after nothing. When the device starts sort of flashes for less than second and than it goes into Rover Mode. So it seems that there is no attempt to connect to wifi or showing how many days I have left
I got it working again (not sure how) but today I cannot see any feedback and for sure I cannot see pointperfect working (where it worked the first day).
If I connect to the config page it says that my key is still valid for 21 days.
Thanks in advance
