I just hooked up the Venus GPS-09133 eval board over USB and am having trouble getting any signal at all from the satellites, even outdoors. This is what I usually get from the serial port:
$GPGGA,193130.000,0000.0000,N,00000.0000,E,0,00,0.0,0.0,M,0.0,M,0000*64
$GPGSA,A,1,0.0,0.0,0.0*30
$GPRMC,193130.000,V,0000.0000,N,00000.0000,E,000.0,000.0,010210,N*7D
$GPVTG,000.0,T,M,000.0,N,000.0,K,N*02
Occasionally it’ll hold on to a satellite for a few minutes and sync up the clock, but it has never gotten enough for a position fix, even after letting it run for 8 hours. I’m using the GPS-00177 antenna. Moving the antenna around does affect the SNR, so I don’t think the antenna connector is defective. Any advice?
