I’ve got a Venus module (GPS-09133) with antenna (GPS-00177). This used to work great, I was able to get a satellite fix both on my window sill inside, and obviously outside. Used it with a 3.3v Arduino Pro and directly with my laptop (via a 3.3v FTDI).
As I said it all worked great a few months ago. I pulled it off the shelf last week and now it won’t get a fix. I connected it up with my laptop again with the FTDI and took it outside, and it never gets a fix. I get the NMEA strings correctly, but never with any valid data. A few sample lines:
$GPRMC,115954.700,V,0000.0000,N,00000.0000,E,000.0,000.0,280N*76
$GPRMC,115954.800,V,0000.0000,N,00000.0000,E,000.0,000.0,280N*79
$GPRMC,115954.900,V,0000.0000,N,00000.0000,E,000.0,000.0,280,N*78
I was able to change the configuration on the Venus (update rate, NMEA config, etc). So I believe the Venus unit is functioning correctly, just no longer getting a fix. So I suppose the antenna has gone bad? Anyone have a similar problem?
