Hi all,
A few weeks ago I bought the GPS minipod, the one with the small PCB ceramic antenna, it couldn’t fix so I sent it back.
On the advice of the support rep at SF, I bought the Venus unit with the SMA connector and the ‘Antenna GPS Embedded SMA’ and it still won’t fix. Here is the NMEA output I’m getting:
$GPGGA,220645.000,0000.0000,N,00000.0000,E,0,00,0.0,0.0,M,0.0,M,0000*6A
$GPGSA,A,1,0.0,0.0,0.0*30
$GPGSV,1,1,01,13,00,000,32*4B
$GPRMC,220645.000,V,0000.0000,N,00000.0000,E,000.0,000.0,261009,N*7D
$GPVTG,000.0,T,M,000.0,N,000.0,K,N*02
As you can see it can’t find any satellites, I’ve done the RTFM thing (I have been known to not do this
 ) and can’t find anything else I can do. I’ve even left it run for 30minutes and still no change.
A little about my environment, I’m sitting in the 30th floor of a condo pretty close to a window. I know it’s far from perfect but I figure my iphone can get a fix even in the elevator this unit would too, considering the antenna.
I might be a little off-base with this theory, and I’m relatively new to electronics having been a software guy for so long. Does anyone have any thoughts/suggestions?
