Maybe something that uses this new chip from Analog Devices:
AD7490: 16-Channel, 1MSPS, 12-Bit ADC with Sequencer in 28-Lead TSSOP
On the other hand, is something like this available and I just haven’t found it on sparkfun?
MAX1230 is similar: 300ksps, 16 channel, fifo, oversampling,…
Angelo
I don’t care much who makes it so long as it is generic enough that it could be applied to many applications. It might be nice if a breakout had enough room for some passive filtering and could be ‘daisy-chained’ serially (SPI, I2C or something) too…
oops ::edit::…
nevermind the datasheet aint up
ill check it out when the datsheet link is working.
