How do I enable RTCM MSM7 messages output for my SparkFun RTK mosaic-X5 ? I tried it several times but it always output MSM4 messages ?
It should be very similar to the link above’s instructions
I can see the default MSM4 message output (explained in the provided link).
I tried to select MSM7 message, but it still output the default MSM4 message. How do I make this receiver output MSM7 message ?
You can also try the CLi; see pgs 63, 214 to enable a msg set that includes msm7 ( there are also other that cover msm7 msg types), and you can try setting it manually like the examples in the relevant section
Could you advise where can I find the document :: CLi (pages 63, 214) ?
Presumably the Command Line Interface (CLI) portion of the Septentrio Mosaic Firmware Reference Manual..
