Although this question is intended for the Leonardo, I need the answer for the UNO too since the Leonardo is being discontinued.
How many fully addressable RGB pixels can the Leonardo/UNO reliably control on the signal bus? Please note I am asking this question about control power, not raw power for illumination. I fully understand the requirements and techniques for power distribution amongst hundreds of pixels, but I don’t understand the limitations of the control signal power which must be provided from one end of the string and then serially traverse those same hundreds of pixels. I assume there may be two answers to this question; the total numbers of pixels by all pins, and the total number from an individual pin since different pins can control separate strings of LEDs.
Thanks for the help.
