I’ve used the example sketch LoRaWAN_node_ABP_method.ino with a Sparkfun ExpLoRaBLE to create a LoRa node. I’ve registered this device with TTN and see data being uploaded through my gateway. In the TTN console it looks like my board is using a spreading factor of 7 and bandwidth of 125khz.
settings": {
“data_rate”: {
“lora”: {
“bandwidth”: 125000,
“spreading_factor”: 7,
“coding_rate”: “4/5”
“frequency”: “904500000”,
“timestamp”: 3415167747
I’d like to see if a SF of 12 and bandwidth of 500khz increases transmission range.
Does anyone know how to configure those parameters?
